Survey scan
Posted: Thu Oct 04, 2007 1:04 am
I am trying to distinguish between a survey scan on a triple quad and data dependent MS/MS on a finnigan ion trap. I fully understand the data dependent MS/MS on a trap but have never performed a survey scan on a triple. My main question is - do yo have to specify the masses that you want to perform MS/MS on on a triple survey scan or does it pick the ions for you based on user settings such as threshold.
