Source Cleaning Method?
Posted: Fri Sep 28, 2007 2:06 am
by EnvironLab
I pretty much follow the Agilent source cleaning method for 5973 EI sources - Water/abrasive powder slurry, qtips, and solvent sonications (minus the meoh). I've heard of several others or slight variations there of. Any others out there?
Posted: Fri Sep 28, 2007 1:03 pm
by Schmitty
I used the green abrasive paper only, followed by methanol/acetone/DCM sonication.
Posted: Fri Sep 28, 2007 7:25 pm
by tima
I have used their methods with great success so maybe you just a few tips. Make sure the surfaces you clean are shinny like a mirror and pay particular attention to the inside surfaces of the source (i.e. the repeller and the ion chamber get especially dirty). I don't use the green paper and if I do I rub some of it against itself to lower it's abrasiveness. So maybe you can share with me what are the deciding factors (tune parameters) for ion source cleaning?
Posted: Fri Sep 28, 2007 10:22 pm
by EnvironLab
I've heard some say that the green abrasive paper works fine for them and others who have said it's too course of a grit. I have only used it a few times on really dirty parts and that was followed by the alumina slurry scrub. I was just curious to see what other methods were being used which might save time or increase effectiveness. In general, when I see the sensitivity drop, I figure the source is getting dirty.
Posted: Sat Sep 29, 2007 6:21 pm
by leadazide
One thing I have experienced is that when making the AluminumOxid slurry using glycerol instead of water makes it easier cleaning the aluminumoxid off the parts later..
Posted: Tue Oct 02, 2007 10:06 pm
by EnvironLab
Have not tried the glycerol before. Had a guy from Agilent tell me he used to just run the parts under a tap to remove all of the aluminum oxide.
Posted: Tue Oct 09, 2007 10:03 pm
by mtorrey
Our Agilent service engineer uses this stuff called "barkeepers friend." Can be had from most grocery stores:
http://www.barkeepersfriend.com/
But I still use the conventional aluminum oxide and green paper method.
Mike
Posted: Wed Oct 10, 2007 9:20 pm
by EnvironLab
Interesting. Barkeepers also looks to be a bit cheaper. I could probably use the Alzheimer's bib as well considering the way I eat. :pig:
Posted: Thu Oct 11, 2007 9:51 am
by gcguy
I use standard automotive chrome cleaner for mine. It smells nice and can be used on the open bench. I rinse well afterwards and have never had any problems with residues.
GCguy
source cleaning
Posted: Fri Oct 12, 2007 3:11 am
by sllimbri
I used to use the powder and green paper method until I discovered that metal polish works best. It really polishes the metal as opposed to scratching it. A smooth polished surface is easier to clean than a scratched surface where dirt can accumulate.
Posted: Mon Oct 15, 2007 9:55 pm
by EnvironLab
I may give these polishes a try. Anyone ever use finer grit sandpaper?
Posted: Fri Nov 09, 2007 3:59 pm
by Ron
If you use one of the metal polishes be sure to sonicate is methanol afterwards. The polishes usually contain waxes that should be removed before reinstalling.
