dear friends
Posted: Thu Sep 20, 2007 5:20 pm
i am involved in the stability study of Imipenem and Cilastatin. For a couple of months i am wasting my time in method development for the same. my aim will be to develop the stability indicating method, which will well separate drugs as degradation products of the both drugs formed during different stress conditions, like acidic, hyydrolytic, oxidative, photolytic etc.
second thing is i will be transferring the method to LC-MS, so volatile buffer is essential.
till now, i tried, phosphate buffer with different pH (3.5, 4, 4.5, 6, 6.5, 6.7, 6.8, 7, 7.2) i.e. either K2HPO4 or KH2PO4. non gave better results. in fact, below, pH 4.5 at any pH i got two peaks of Imipenem fresh sample with the same uv-scan in PDA. as per literature report i perdicted as its rotamers (cis and trans), peak broadning and shape were horrific and also those rotamers never baseline separated.
then i moved to volatile buffers, first tried ammonium acetate, at pH of above adjusted with ammonia or acetic acid,
lastly i tried formate buffer, again results were disgusting, there is not a single LC-MS method for the drugs reported in literature.
i also tried BP assay method, it was just ok for assay but not suitable to proceed with to further develop stability indicating method
not yet tried USP method.
lastly i landes with the 25mM ammonium acetate and ACN method, again bad peak shape, surplus tailing and two peaks of fresh sample not being separated at base line of IMIPENEM.
i am using supelco discovery C-18 column., shimadzu HPLC system.
too much frustrated till now
i would be really indebted to the persons who help me to cast the prper way
