Particle size? Pore size?
Posted: Tue Sep 18, 2007 8:37 pm
The label on an HPLC column always tells something like: 4.6*150mm, 5um, 100A......
I assume 5um is the particle size and 100A is the pore size. Is this right? Someone corrects me?
Is there any correlation between particle size and pore size? Is it like the smaller the particle size, the smaller the pore size? Or are they totally independent?
I understand that there is an optimal pore size for each analyte if you care to look into the molecular size.... How about the particle size? Since smaller particle size yields greater column efficiency, is it always better to use smaller particle as long as pressure doesn't built up too high?
