Sugar Analysis with Anomaous Peaks
Posted: Thu Sep 13, 2007 2:04 pm
Hi All
We are running a chromatographic system involving mannitol and sorbitol on a column from Machery-Nagel: VA 300 7/7 Nucleogel Sugar 810 Ca 300 x 7.7mm. Please find attached chromatogram.
Separation conditions are as follows:
Column Temperature: 85C
Mobile Phase: Deionized Water
Flow Rate: 0.5ml/min
Detection: RI
Injection Volume: 20uL
Conc of Solutions: 50mg/mL
As you can see from the chromatogram the peaks are observed to front anomalously.
Could you help us on this issue?
Thanks for your co-operation
