Fundamental questions on HPLC
Posted: Thu Sep 13, 2007 10:04 am
I am not very sure with some of the following terms:
1) Polar
-when you say the sample is polar, what do you mean? Is it the sample will only dissolve in water or aqeuous?
2) Reverse phase
-If you want to run HPLC, what does this term mean?
3) LOD
- Am I right to say that this is the minimum standard concentration that the HPLC machine can detect for a particular method?
- Does this value change if Iwere to apply the exact same method when I run on a different set of HPLC machine?
4) LOQ
- Am I right to say that this is the minimum concentration for the spike standard set that the HPLC machine can detect for that method?
- Assuming my LOD is 0.1 ug/ml for this machine. But if I were to run my samples on another set of the machine, can my LOD value now change? If that's the case, does it mean that I have to re-determine the LOQ value again each time I run on a different set of HPLC machine?
5) Peak
- If you were to manual do a peak integration, do you take the analyte peak that is below LOQ even though it was eluted at the correct retention time? Is there any guidelines?
Is that any course or material on method validation and peak integration?
Thank you for taking the time to read this. I would appreciate if anyone can give me some advice.
1) Polar
2) Reverse phase
3) LOD
4) LOQ
5) Peak
