Agilent 1100 Injection Repeatability
Posted: Thu Sep 13, 2007 1:22 am
Hi all,
I have a flukey thing that happened a little while ago and have not found a cause.
I have an Agilent 1100 system with a good performance history. I inject assay samples in duplicate and have to meet a ratio spec. Normally this is never a problem but I had a run of 13 samples (dual component) and had 2 ratios go out for one component and 5 ratios go out on the other component with only 1 sample in common. We have ruled out vial misplacement (we inject out of separate vials) and our metrology department came up empty.
Any ideas as to the cause?
