ammonium acetate buffer
Posted: Sun Sep 02, 2007 10:32 pm
Hi, can I make 0.2M ammonium acetate buffer at pH 5.5 using ammonium acetate and acetic acid?
Can someone please help with the calculation? I weighed out 15.2g of ammonium acetate I took the pH of ammonium acetate in water to be 7 and adjusted the pH to 6 with acetic acid. Is this right?
Thank you
Olivia
Thank you
Olivia
