Long-term HPLC RRF Stability.
Posted: Wed Aug 29, 2007 7:46 pm
This should be easy: I'm looking for references describing the long term stability of RRFs in HPLC methods.
Complete Info:
My lab's used a RRF method on our HPLC units for the last 7 years. Every analysis is preceded by a standard that we use to re-compute the RRF for the instrument. We use this pre-run RRF to prove statistical control over the instruments. Problem is that minor differences in equipment set up, standard preparation, etc. frequently give us control errors for our on-side of aim rule. (Frequently as in 5 times a year, or so). I've reams of data proving the stability of the method, and proof that the minor fluctuations we see in the RRF do not significantly affect the methods' uncertainty.
So I'm trying to eliminate the on-side of aim control rule for this instrument, but can't because I can't provide any external sources touting the stability of RRF methods in general. There are plenty of method-specific sources, but nothing general enough to take to my superiors as proof.
Help please?
ps. This is not a pharmaceutical application.
Complete Info:
Help please?
