HPLC METHOD FOR IMIDAZOLE
Posted: Wed Sep 01, 2004 6:17 am
by SRINIVASAN
Hi to all,
I want devlop a new method for estimation of IMIDAZOLE by Reverse Phase HPLC. Already i have done with YMC ODS (150 x 4.6, 5mm) by using mobile phase 50:50 (acetonitrile : water: 0.1% TEA) . I found the peak is comming before second minute then i change the mobile phase concentration to 20:80(acetonitrile : water) eventhen i did not get any improvement.
Anybody of you can suggest good method for the same. I want retention time about 8.0 minute
Thanks in advance
Posted: Wed Sep 01, 2004 9:17 am
by Newman768
Hi SRINIVASAN,
I doupt that you can bring Imidazole on your YMC ODS-A on a retention time of 8 min.
As far as I remember Imidazole is a base. So try a buffered mobile phase (80 to 90% of water) at pH around 8 to 10 with a column like Waters XTerra or Zorbax Extend.
Any form of ion pairing chromatography should work too.
(Guess, the guy from Alltech Sep will post his suggestion in the next time.)
Posted: Wed Sep 01, 2004 9:58 pm
by Uwe Neue
For such a polar base I always recommend to use HILIC: use a silica column with a mobile phase of about 80% acetonitrile and 20% water. You may need to adjust the pH with a small amount of acetic or formic acid.
Posted: Sun Sep 05, 2004 6:29 am
by maris
From my experience, HILIC is much suitable for imidazole and its derivates. Try Si-gel column with water/ACN at low pH.
