fluctuation in column back pressure
Posted: Thu Aug 16, 2007 10:04 am
by vijaykhetmalis
my hplc instrument gives a lot of fluctuation in back pressure, it sometimes increases to high pressure. what could be reason behind this and what is the solution for it?
Posted: Thu Aug 16, 2007 12:59 pm
by DR
More details please.
If you're running a gradient, this is quite normal. For isocratic runs, this signals a problem with the column or pumping system...(or the plumbing between them).
Posted: Thu Aug 16, 2007 4:21 pm
by Mark Tracy
Or the detector flow cell
Posted: Mon Aug 20, 2007 1:07 am
by syx
I think there is problem with the pump... please inspect the check valves.
