Baseline Problem
Posted: Thu Aug 16, 2007 4:25 am
i Am Using 0.1% H3PO4 in ACN And Also in Water on Gradient Method and Column is Waters Symmetry C18,250 X 4.6mm,5µm.
we Face a Problem When We Inject ACN or MeOH to Check Baseline for System Suitability it gives a small peak at R.T. where our a coumpound isomer is retained.
we tried it on five HPLC and also with new column. we used ACN , MeOH and Water From Merck Gradient Grade.
what was the main Problem.
