Ion-pair Chromatography: Revalidation issue
Posted: Wed Jul 25, 2007 10:56 am
Dear colleagues,
I shall greatly appreciate if you could share your opinions and experience in this particular subject in IPC (ion-pair chromatography).
What is the problem?
It is clear that use of ion-pair agents can enhance peak shape and retention time when common approaches, such as modifying eluent ratios or changing stationary phase, fail to improve resolution of polar and ionized analytes, especially when they are in large numbers, e.g. impurities of active pharmaceutical ingredient. Changing one ion-pairing agent with another also changes the chromatographic separation. This change may lead to different resolution, inversion of retention and fail in achieving the system suitability.
So, when using ion-pairing agent that slightly differs in structure with the prescribed ion-pairing agent in the method, questions arise whether the changed method should or should not be revalidated.
The chain lengths of the ion-pair reagents enable selective separation of the analytes. The longer is the chain, the more hydrophobic is the counter-ion, and therefore, the greater is the retention. Retention may increase by a factor of almost 20 when going from pentyl to dodecyl alkyl chain. In either case, increase in the alkyl chain length of the counter-ion increases retention in reverse-phase ion pair chromatography by up to 2.5 times per added - CH2- group in the counter-ion.
My question is: if you change the prescribed ion-pairing reagent with similar (e.g. heptane sulfonic with hexane sulfonic) and if you check the critical chromatography parameters of the changed method (resolution, k', peak symmetry) is it sufficient after performing the system suitability, checking the selectivity and method robustness to accept the changed method (after partial revalidation)?
Your help is greatly appreciated
Sincerely,
Zoran
Sincerely,
Zoran
