someone can help me?packing unrepeatable
Posted: Wed Jul 18, 2007 8:30 am
I met with a strange phenomenon!I am packing our spring columns ,all the conditions were the same ,the same packing system,the same HPLC system,almost the same amount silica (C4,300A,10-15u,214TPB1015),about 280g,the same column hardware!this time ,with higher packing pressure about 1000psi,last time the packing pressure is about 750psi. and the result column pressure drop is higher than the former one,this time is 3.3MPa,last time is 2.0MPa,but when I test the column effiency,I found that the testing probe's(Naphthalene and 1.54mg/ml phenanthrene) retention time decrease from the former 25min to the now 20min,finally,when I press the silica out of the column ,I find that the length of column bed is almost the same!I do not know why is so ? do you have some advices ?will the piston speed affect the column efficiency a lot when packing the column?
the lot of the silica was different ?and the ACN used as mobile phase maybe from different company,I forget it!
testing conditions as follows:
mobile phase:50%ACN/50water
flowrate:50ml/min
wavelength:254nm
flowrate:50ml/min
wavelength:254nm
