Nano Flows Surveyor MS pump
Posted: Tue Jul 17, 2007 1:28 pm
I would need to contact to somebody using LTQ system with Nano I or NanoII and the Surveyor MS pump and the Micro As Autosampler , working in Nano mode. The configuration I need opinion is using teh paptrap for proteomics and NANO flows. ...Basically would like some advise on how the instrument perform in this way?
Do you think is better to have a dedicated solution in nano, or is Ok to split flow with a good pump-
