Fisons GC8130 oven problem
Posted: Fri Jul 06, 2007 12:08 pm
Hello everybody
I'm writing here because I'm not able to find out an oven flapper motor assembly mounted over a Fisons Instruments GC8130.
I've already disassembled the motor assembl and tested the motor itself wich is ok (functional). The motor is a Micro motors with planetary gear working at 12V dc.
I think the problem arise with the little electronic board included in the assy.
This piece of electronics I think convert some signal coming from the logic board to drive the motor itself.
It is identified by a label: MCN910.
It contains 3 capacitors, 1 resistor and an hybrid circuit ...
Could anyone help me on find out this electronics board or the complete assy ?
Thanks in advance
MSD5970
MS specialist
Thanks in advance
MSD5970
MS specialist
