Chromcard error
Hi
While, I am trying to change the chanel from A to B in Chromcard, the message "Subscript out of range" appears, and after clicking OK Chromcard is shuting down :(.
Please help.
Radoslaw Bonikowski
Sounds to me as if one of the files is corrupted. Try uninstaling and reinstalling the software. This will not affect your datafiles but depending on the Software version can reset text files like datapath options. You do not state which version of Chromcard ? For old 16 bit you should be running V1.21 for 32 bit version 2.4 or later.
Chromcard is still supported by the factory so try contacting your local Thermofisher supplier.
If in the UK we can help www.ceinstruments.co.uk
Thank you,
all files were fine, but in the sample table were toooooooooooo much entries :) and after deleting the mth file from chromcard folder everything is all right.
thanks again
Radek
