We have been using Empower Build 1154 + Autoarchive for a time but now because of company policies we must move to Empower 2 Build 2154. We would like to keep the Autoarchive option as the tool to archive our projects.
We have installed Empower 2 and Autoarchive in a test platform and it seems that everything is OK except when using the "Records Archive and Remove" tool. Sometimes the records are removed and somtines not and at the end you have such a maze in the table that you can not trust in what you see. Waters tell us that although Autoarchive has been validated also in Empower 2 we should move to EDM software which is a much more complex (and expensive) solution that we want.
Is there anyone working with Empower 2 and Autoarchive? If so, do you have the same problems?
Thanks a lot for your answers
