need help?
Posted: Fri Jun 08, 2007 2:08 pm
hi:
I meet a strange phenomenon!have you ever met before?
we have a 50mmID*250mmL column here,when we test the column efficency with
mobile phase: 50%ACN:50water
Detector was 254nm,
flowrate:55ml/min
silica:C4
testing probe:paraben
everything is ok!but when I change the mobile phase to 50%MeOH:50water,the column efficency will decrease a lot ,and the T-factor will encreased a lot !
I just want to know why is so ?and do you have some recommendation on testing the column efficiency(50mmID*250mmL,C4)
thanks !
Detector was 254nm,
flowrate:55ml/min
silica:C4
thanks !
