looking a guard cartridge for the diol column
Posted: Wed Jun 06, 2007 4:34 pm
I’m looking guard cartridge for the Develosil diol analytical column (250 x 4.6 mm, 5u particle size). Could you recommend which type of cartridge will be good alternative for develosil diol column, because I could not find exact cartridges from phenomenex to connect the develosil diol column. I’m thinking it might be either C18 or RP-1 cartridges as alternative will be used on this column but I would have your advice.
The analytical conditions of the column
will be below;
Flow rate: 1 ml/min
Binary mobile phase:
A: acetonitrile: acetic acid (98:2)
B: MeOH:H2O:acetic acid(95:3:2).
Mobile phase A (100 ~ 60%): Mobile phase B (0 ~ 40%)
pH:1- 10
Flow rate: 1 ml/min
pH:1- 10
