Pressure go zero
Posted: Mon Jun 04, 2007 8:10 am
Hi at all,
I have another problem with my HPLC that I can't understand.
When I turn on the HPLC monday or when I leave my HPLC turn off for 2 or 3 days when the gradient go to 70% of MeCN break down the pressure and to return to the normal situation of pressure I have to open the purge valve and turn off the pump and follow turn on for many times until the pressure when I close the purge valve is normal. I think that there is some air balls thet I must flow out.
My HPLC is a Agilent 1200 with quaternary pump, degasser and DAD.
Thank
PS: This forum is fantastic
Thank
