Headspace Artifact Peak with DMA
Posted: Fri Jun 01, 2007 3:25 pm
I am analyzing a sample by headspace using the diluent DMA. I have an Agilent G1888 using the settings:
Flow: 20ml/min
Oven: 80°C
Loop/Line: 95/95°C
Vial Eq/Pressuriz time: 45/0.1 min
Loop Fill/Eq time: 0.2/0.1 min
Inject time: 1.0 min
The run is 15 min long going from 50 to 230°C. This is a capillary column (G43) 30x.0.53x3µm with a flow of 5ml/min and a split of 15:1. DMA comes off at 7 min, but I get a growing artifact peak around 2.4min right after methanol (analyte). It tails good too compared to the sharp analyte peak. I have removed this peak once before, but on another system (developing the current configuration. Now its back.
Any thoughts on this? And how I can remove it?
Flow: 20ml/min
Oven: 80°C
Loop/Line: 95/95°C
