Herbicide analysis [July 9, 2004]
Posted: Tue Aug 24, 2004 6:27 pm
By Maja on Friday, July 9, 2004 - 03:58 am:
Does anyone have some experience with phenoxyacetic acid herbicides analysis with HPLC.
Could you suggest some method. The matrix is water.
Thanks.
By Russ on Thursday, July 15, 2004 - 07:40 am:
These are very common herbicides that are in the application libraries of most chromatography supply companies. Among others try:
http://www.alltechweb.com
http://www.chem.agilent.com
http://www.sigmaaldrich.com (for Supelco)
http://www.waters.com
All of these, and many others, have application libraries you can search. If you are not sure what compounds to look for, a very common phenoxy acid herbicide is 2,4-D
Thanks.
