Baseline Drop on one system only
Posted: Fri May 18, 2007 4:02 pm
Hi Everyone, this is my first post so maybe you can help
I am currently running a gradient method on my LC that essentially runs from a mobile phase containing an aqueous buffer and acetonitrile to one that consists purely of acetonitrile. Detection is UV (above 260nm)
The problem is this. Normally the baseline for this method is either totally flat or we see a slight rise. (this has been so on three different instruments) When trying to use this method on another instrument we are seeing a decline in the baseline due to the gradient.
So far I have tried using different batches of mobile phase that I know give "normal" results on another system, different lines for the aqueous and acetonitrile phases (its a quaternery pump) and even making everything up from scratch but to no avail.
Any suggestions?
Any suggestions?
