- admin
- Site Admin
Does anyone have some experience with phenoxyacetic acid herbicides analysis with HPLC.
Could you suggest some method. The matrix is water.
Thanks.
By Russ on Thursday, July 15, 2004 - 07:40 am:
These are very common herbicides that are in the application libraries of most chromatography supply companies. Among others try:
http://www.alltechweb.com
http://www.chem.agilent.com
http://www.sigmaaldrich.com (for Supelco)
http://www.waters.com
All of these, and many others, have application libraries you can search. If you are not sure what compounds to look for, a very common phenoxy acid herbicide is 2,4-D
