Waters Oasis HLB Extraction plate
Posted: Wed May 16, 2007 9:36 am
I am currently using the Waters Oasis HLB Extraction plate to extract my plasma samples.
I will condition the 96 well plate with 100% methanol, follow by equilibrate with MilliQ water. Once finish, I will load in my diluted plasma samples follow by 2x washing and elution of samples and complete the whole extraction. Each of my plasma samples is done in duplicate. All these samples will be analyzed using HPLC, PDA.
The problem that I encounter is:
- not all samples will go through. Some will take a longer time while other will be faster. As a result, the final analyte result of the same sample will vary quite a lot.
I will appreciate greatly if anyone can give me some suggestions on how to overcome the above mentioned problem.
Can anyone enlighten me the principle in this type of extraction method?
What is the purpose of doing conditioning follow by equilibration?
Thanks for all your time.
