Acid chlorides...GC or LC? [August 2, 2004]
Posted: Mon Aug 30, 2004 6:38 pm
by admin
By mmm on Monday, August 2, 2004 - 12:31 pm:
I wondered if anyone could expand on the idea of analyzing acid chlorides without derivitization.Two of the impurities we are looking at derivitize into the same tri-ester.We have also tried normal phase HPLC (the main component is an anhydride)but response factor is unpredictable.This is espicially true for the main component.As the purity gets higher from 98%-99% the main component practically disappears.I was using a silica column, but will try a CN column to avoid any possible reaction with the silica.
Any information on a GC or LC method would be helpful.
