Column volume
Posted: Sun May 13, 2007 2:06 pm
For a long time I calculated the equilibration time using column volumes based on void volumes, but recenctly in new job I met that people use the column volume based in the geometrical dimensions of column, what causes a big diference in the time. I use a column volume of 2,0 ml (4,6x250) and they use 4,2 ml for same column.
In most papers of LCGC it seems that they use void volumes as column volumes, but IUPAC have some official definition on column volume based only in geometrical dimention.
Am I wrong or there is no consensus on this?
Fabiano
Fabiano
