Internal Standards and other Wild and Wacky Ponderances
Posted: Thu May 10, 2007 5:10 pm
Could anyone recommend a book or article on the basis behind internal standards, how to select an internal standard, how to make calculations with internal standards?
We are running an analysis on 8 VOC of different chemical classes (Acetone: 56.15C ; Toluene: 110.65C ; Hexane: 68.75C ;Propanol: 97.15C ;Ethyl Acetate: 77.05C ; 1-Heptene: 93.85C; Propionaldehyde: 48.85C ;Pentafluoroethane (R-125):-46.15C) injected into the GC/MS in the vapor phase and making calculations using an external standard. Well, we will at some point. At the moment, I calculate only one compoun d at a time to kind of see where we stand in terms of error.
Someone suggested we use an internal standard so that as the decrease in analyte response isn't a problem overtime. Would we have like a standard for each different species in the gas standard mix? That's what I'm not sure about?
If we have a standard in a gas cylinder, would we need to reorder a cylinder with our standard gases and have the internal standard added to the cylinder? Or do you buy a completely different cylinder with the internal standards?
