HPLC Assay
Posted: Tue May 01, 2007 4:45 pm
Please help me with two of my questions about HPLC assay:
1. I read a document saying" report HPLC assay results on the dry-basis as well as it's as-is value". What's the difference between the dry-basis value and as-is value?
2. "Weight/Weight assay result vs. %AUC results. My understandng is weight/weight result is obtained by using external standard method; %AUC result is obtained by assuming response factors are the same for every peak and calulation of %peak area. Am I correct about this?
Thanks for your help!
