Shifty BHA
Posted: Tue May 01, 2007 11:45 am
Hi folks,
Got a question. Hope some one can help.
We were trying to separate BHT and BHA (Butylated Hydroxyl Toluene and BH-Anisole) on a C18 column using 50/50 Water/ACN (I think). Anyway, we found that BHA was very sensitive to slight mobile phase change. Adding a little bit more water and the BHA peak shifts way off the chromatogram. BHT was okie though.
Just wondering what causes this......I thought it might be a column equilibrium issue or are there some thermodynamic explanation for this behavior?
Thank you all.
Thank you all.
