HELP WANTED !(Varian CP 3800)
Posted: Fri Apr 27, 2007 1:46 pm
I have problems in establishing split ratio-splitting wanted relation.
At first I've menaged to have splitting measured with flowmeter around 40 ml/min when the split ratio set in the method was 40.
Nowadays at split ratio 40 I have value around 129-135 ml/min on the flowmeter.
What could be the cose?Why don't they follow each other?
Septum,column and detector are checked!
How to establish splliting arond 40 when I have set in the method split ratio at 40?????
Could possibly water in H2 geneartor that has lager concentration of co2 have influence?
Thank you!!!!!
Thank you!!!!!
