agilent chemstation problem
Posted: Thu Apr 19, 2007 10:46 pm
i was running a HS GC test the other day and about 3 hours in, the status window for my headspace showed disconnect. The sequence was still running like normal, except everything after that error, the data it collected are saved into another folder (not the one i specify in my sequence parameter) and the file name has changed and sample name has changed too.
the headspace error message i got is
CP Macro HSerr: no reply received for command: 'HS00CS
has anyone have had this problem before?? this is not the first time i've encountered this.
