API 2000 LC/MS/MS problems
Posted: Tue Apr 10, 2007 1:39 pm
I reciently adquired an API 2000 LC/MS/MS, and I'm founding the following probles:
When I try to made an autotune with PPG standard (without dilution) y see that the signal is about ten times less as in the specifications indicates.
The signal is not stable, when I made infusion of PPG the signal in the TIC window increase in the time. When I stop the adquisition and then press start, the signal don't begin at the last value in the other run, this begin in the same initial value, and then increase.
When infuse standards (pesticidas), I only obtain the Na adduct, the +H adduct, is not present. And of course the signal increase and the sensitivity is low.
I hope, someone can help me!!!!
Best regards
Best regards
