Methyl iodide by liquid extraction in pentane
Posted: Thu Apr 05, 2007 4:42 pm
by rajdeeproy
Dear all
I wanted to know is it possible to mesure methyl iodide by liquid ectraction in pentane?
rajdeep
Posted: Mon May 14, 2007 7:43 pm
by sassman
I am guessing you will use GC. Negative chemical ionization mass spec should work nicely for detection. Other options would be electron impact, positive chemical ionization, or maybe ECD. FID would also work if you don't need sensitivity, but the problem will be your solvent peak will co-elute with the idomethane. You could try a solvent with lower volatility so that the solvent comes out after the idomethane. What matrix are you extracting from?
Posted: Thu May 17, 2007 10:53 am
by rajdeeproy
I am extracting sea water samples directly in the collection vials (100 ml volumetric flask ) chilled at 4 degree.
