FPLC Air gap
Posted: Sat Mar 31, 2007 2:01 pm
I am using Amersham's pre-packed Superdex 200 column and their FPLC system.The problem is, whenever I run the column, a gap begins to develop at the top and the column seems to start compressing.When I run the column inverted,the matrix is restored to normalcy.I have washed the column with 20%ethanol to remove any particulate matter stuck inside,but didn't see anything come out in the UV.This keeps happening and leads to an increasingly high back pressure.
Any suggestions please?
Saraswathi
Saraswathi
