Troubleshooting separating carbohydrates on Econosil NH2 col
Posted: Tue Mar 27, 2007 12:07 pm
Hi, there!
I have an Econosil NH2 column which was initially shipped in hexane:ethanol=95:5. Prior to use it in reverse phase mode i washed the column successivelly with n-propanol, acetonitrile and acetonitrile:water=75:5. When i tried to separate some monosaccharides i've got same retention time for each other. It seems that carbohydrates passed through my column without any retention. I think the column must be first equilibrated prior to use it, but i don't know how. Which salt or buffer are suitable for amino bounded silica columns.
Any suggestion will be appreciated.
darth.anghel
darth.anghel
