HPLC for Polyvinyl Alcohol (PVA)
Posted: Tue Mar 20, 2007 4:48 pm
I am trying to switch a method from a UV assay to an HPLC assay for the quantitation of Polyvinyl alcohol (PVA). In the previous method the sample is complexed with iodine so as to give a uv absorbance, however i don't believe this to be very accurate as it is dependent on free hydroxyl sites.I have tried the following using an RI detector.
1) TSKGel G400PW 7.5mm ID * 30cm with a potassium phosphate buffer
2) C8, C18, CN with variuos Acetonitrile/ water concentrations
3) CN column with ACN/ H2O (pH2.20)/ 2-Propanol (58/33/9) flow 0.7 mL/min
In 3) i have a problem in that my retention time is approx. 2-3 mins and i am worried that when stressing my samples and placebo (containg Povidone) for specificty studies that i will have excipients coming out at this short retention time. Changes in mobile phase (conc. and pH) does not seem to affect the retention time significantly. Is it being retained at all on the column?
4) I have also tried a Hillic column with various conc. of acetonitrile/ water
Am i on the right path using an RI detector- is this sensitive enough for detecting possible impurities?
I am new to this "game" of method development and i apologise if i am missing the obvious but any suggestions would be very much appreciated. Thanks.
