Glucosamine and chondroitin by HPLC.
Posted: Tue Mar 20, 2007 6:00 am
Hello All
Long time since I posted.
I have a problem and I need help. I'm trying to estimate glucosamine and chondroitin on the same column and I've failed miserably.
We have: Agilent 1100 quarternary system, RI and UV detectors, and only three column chemistries at hand - C8, C18 and NH2.
We have tried all three, with no success. The problem is both glucosamine and chondroitin are merrily soluble in water and it's just not possible to retain either of them, long enough to attain baseline separation.
Thus far, we've tried:
C8, C18 and NH2, with 100% ACN, and with phosphate buffers at pH 2, 7 and 8, with varying amounts of acetonitrile. No separation achieved. Co-elution within three minutes.
The official method for chondroitin uses size exclusion, with RI detection, while that for glucosamine uses a C8 with UV detection. But we've been given the task of separating both glucosamine and chondroitin on the same column.
Given our restrictions on the column chemistries available to us, my idea was to try and increase glucosamine's retention time on the column, by any means possible. I didn't expect chondroitin to be retained at all, since its mol weight is above 50KDa, and it won' t be retained on any 100A column. One would expect chondroitin to elute fast, and it does. Unfortunately, so does glucosamine, no matter what we try.
Ion-exchange chromatography is ruled out. We can't procure an electrochemical detector, just for one analysis.
So I need help.
Do I derivatise? Say, ninhydrin for glucosamine?
Ideas, anyone?
Thanks in advance.
So I need help.
Ideas, anyone?
Thanks in advance.
