Using Diethyl Ether in a Liquid-Liquid Extraction
Posted: Fri Mar 16, 2007 7:51 pm
Hello everyone,
I am testing out an extraction method which requires adding diethyl ether:dichloromethane (3:2, v/v) to my sample. Ive never worked with diethyl ether and my concern is how should I handle the solvent as I remove it from its container (sure/seal), further, should I be concerned about drying down approx 6ml of the solution at the end of the extraction. Thanks
