Polyacrylamide by GPC
Posted: Wed Mar 14, 2007 6:38 pm
Help!! I'm running a clients samples by GPC for Mw determination. The samples are low Mw polyacrylamide. Our first run was an attempt at using PEG reference standards for calibration. Here's what we noted:
1. Calibration is perfectly linear from 200,000 to 100 Mw for PEG samples.
2. Clients samples elute after the lowest PEG standard, suggesting they are very low Mw (<100!!) - this is unlikely
3. A sample of acrylamide monomer elutes after the clients polyacrylamide samples suggesting he does have a polymer not a monomer.
So I suggested we buy and try using some broad Mw polyacrylamide reference standards instead of narrow PEG ones. The only ones available were 20,000 and 3,500 Mw. Along with the monomer, this should provide a very limited rough calibration curve!
But... the PAM broad standards both elute together very early in the chromatogram, earlier than the 200,000 Mw PEG standard.
HPLC conditions:
Column: Shodex OHPak SB803-HQ (polyhydroxymethacrylate) 8x300mm
Eluant: DIW
Flow: 1 ml/min
Detection: UV @ 195nm and refractive index.
Samples all dissolved in DIW on a rotator overnight.
Maybe there's ionic activity? But I've tried using a PO4 eluant and an acetate eluant instead, but this seems to severely affect the background level. I'm going to try a different PO4 pH and see what happens.
But does anybody have any suggestions? Why would the clients PAM samples and the PAM reference standards behave differently under the same conditions?
HPLC conditions:
Eluant: DIW
Flow: 1 ml/min
