Derivatization for aminoacids with a tertiary amine group
Posted: Wed Mar 14, 2007 12:05 am
I am trying to develop a HPLC method for purity analysis of an aminoacid with a tertiary amine group and no chromophores (like dimethyl beta - alanine).
The target impurities are also amino acids with a tertiary amine group.
I don´t have ELSD or MS detector. I only have UV detectors.
Inicially I tried to work at 190-200 nm but the sensibility (as expected) is low in order to search impurities at 0.1 % level.
So I am looking a simple pre column derivatization method, but I have a problem: most of the currently used methods for aa derivatization involve the use of amine derivatizating agents that are only apropiate for aa that contain primary or secondary amine groups.
I need your advice on derivatization techniques for the carboxylic acid moiety that are usufull for HPLC UV detection.
Maybe you can recommmend a suitable approach to tackle the problem.
Thanks in advance for your thoughts.
