Peptide nightmare
Posted: Tue Mar 13, 2007 6:06 pm
Dear All,
A polypeptide I am working with seems to be incompatible with my HPLC methodology. The polypeptide is 6 kDa and the C-terminus is a thioesterified. It is insoluble but is soluble in 5M urea or guanidinium chloride so this is what I use as sample loading solvent. The mobile phase I use is standard H2O/MeCN 0.1% TFA and I run linear gradients, typically 10-60%. The problems start when I try and analyse the polypeptide by HPLC. I get a very weak peak relative to the amount I injected. I know how much I injected as I have analysed the sample by SDS-PAGE and it is 95% pure. The peak I obtain has a very messy tail to it and it is also messy leading up the peak. I have attached a chromatogram and the peak I am talking about has a retention time of 25 min. To me it seems as though the polypeptide is not very soluble in the movile phase. The 0.1% TFA makes the pH of the mobile phase very similar to the pI of the polypeptide and was thinking this may be causing the problems with solubility.
Has anyone had similar problems with peptides and would trying different mobile phase such as propanol seem like a sensible idea? I suppose I could try lowering the TFA concentration as well.
Sat
Sat
