peak separation
Posted: Fri Mar 09, 2007 9:47 am
Here is chromatogram
http://i19.tinypic.com/30j1rg7.gif
First component is desmedipham, then phenmedipham and ethofumesat.
Eluent is 50% MeOH/50% water, flow is 1,3 ml/min.
Column is Supelcosil lc 18 5 um,150 mm x 4,9 mm.
Hplc, UV detector 225 nm.
How can I get better separation of 2nd and 3rd peak?
thank you
thank you
