Two questions about HPLC of neurotransmitter (NE/5-HT/DA)
Posted: Wed Mar 07, 2007 6:34 am
I'm a beginner in HPLC technique. Please forgive my questions if they seem too simple... I'm wondering if anyone here has experienced similar problems before.
1. We collected all of our samples through microdialysis probe implanted in the rat. Will the KCl in aCSF (artificial cerebrospinal fluid) cause the huge dip, when the samples are going through the column and cell? It seems the other components of aCSF doesn't cause any peaks or dips at all.
2. How to control the time when peaks of individual chemical appear, given a certain column? It would be ideal if the NE peak could appear later than 4th minute, so that it won't be influenced by that strange dip caused by aCSF.
Thank you!
Thank you!
