HPLC separation of cross links from collagen
Posted: Thu Mar 01, 2007 7:11 pm
HPLC experts,
This post is the continuation of the previous question about ODS reversed phase column.
I have been trying separate the collagen cross links such as hydroxy pyridinium, dehydroxy pyridinium and pentosidine cross links from collagen. (There is no option here to upload the file that contain these structures)
In the published paper, they used ODS reversed-phase column (8mm x 10cm), 10um, C18 column. 20 mM phosphate buffer pH 3.5 (Analytical biochemistry 278 99-105 (2000).
Presently i have been trying to use the above buffer system to separate all the cross links in single experiment using C18 (4.6mm x 25cm, 5u) column but, with no success.
I got the suggestions that i should work out by changing the pH of the buffer etc. But the questions are
1.Do i need to try different ranges of pH or
2. Different molarity of the buffer
3. Should i try to retain all the cross links first on the column and then try to resolve it
With all the questions in my mind, i thought if i post a specific question, then i may get the specific answers from HPLC people .
The above explained cross links can be obtained from Google search.
Thanks in advance for the inputs
Rajeev
Rajeev
