HPLC Calculations
Posted: Mon Feb 26, 2007 5:54 pm
I was wondering if someone can provide some feedback here... I just want a couple theoretical calculations performed. Assume isocratic elution.
Assume an HPLC column operating at 6000 psi constant flow has now been reduced in pressure to 1000psi. Everything else remains constant except for column pressure. Initially, at 6000 psi, two peaks appeared at 1.5 and 3.0 minutes, both with peak widths of 3 seconds. Is there a way to calculate the new retention times and peak widths with only the pressure having dropped from 6000 to 1000 psi? We can make up a column length, say 4.6 to 150mm C18 column. I was just wondering if there was a simple way to calculate new retention times and peak widths with the pressure change.
Aaron
Aaron
