Mobile phase
Posted: Thu Feb 22, 2007 10:45 pm
Dear experts,
I would really like to get your recommendations on the following issue:
Generally I do not combine the aqueous/organic components of my mobile phase manually. I put them into separate reservoirs on the HPLC and let the instrument do the combining. I do not have any gradients running at the moment.
When it comes to making up some mobile phase for dissolving standards or diluting samples I am concerned that I am not matching the mobile phase accurately. Now while this probably does not have the potential to cause a great deal of difference I am curious to know what the best technique is.
Conscious that this may be a simplistic query:oops: but
Do you:
Measure out the individual volumes in separate measuring cylinders and then combine ...
Measure out the aqueous component (say 60mL) and add the organic component to the 100mL mark...
Measure out the organic component (40mL) and add the aqueous component to the 100mL mark....
I have read many conflicting opinions on this and am keen to know what the expert practice is.
Many thanks
Martina
Do you:
Many thanks
Martina
