TFA concentration
Posted: Wed Feb 21, 2007 2:02 pm
by chichibabin
Hi All,
When doing RP-HPLC with water and acetonitrile as mobile phases I have seen in the literature people adding 0.1% TFA to the water (phase A) but only 0.08% TFA to the acetonitrile (phase B). Does anyone know the rationale for doing this?
Cheers,
Sat
Posted: Wed Feb 21, 2007 3:48 pm
by Noser222
It gives a better baseline that way, since the absorbance of the mobile phase changes during the gradient.
Posted: Wed Feb 21, 2007 4:03 pm
by chromatographer1
Good answer Noser222. But to explain with more detail:
Better baseline in the sense of flatter and easier to integrate later eluting peaks.
I discovered this (before I ever saw it published) in work I did in 1985, although I used 1.0% and 0.9%.
Don't know who discovered it first, but it was very helpful in integrating late eluting peaks. Of course it was shared with our peptide suppliers immediately and I saw it everywhere a few years later. I did not completely understand why at the time it worked so well. I have heard explanations of the phenomenon since but I cannot confirm them so I won't go into it.
It has never made a difference in any analysis I ever did, but of course there may be an exception.
best wishes,
Posted: Wed Feb 21, 2007 8:22 pm
by tom jupille
There was a fairly thorough article on this in LC-GC Europe in early 2003:
http://www.lcgceurope.com/lcgceurope/da ... rticle.pdf
Posted: Wed Feb 21, 2007 11:01 pm
by adam
Tom
Any chance you could also send links to the other articles in this series (Part II, Part III, etc).
Adam
Posted: Fri Feb 23, 2007 7:27 am
by tom jupille
There were only two parts. The second deals with temperature and RI effects:
http://www.lcgceurope.com/lcgceurope/ar ... p?id=75777
Posted: Fri Feb 23, 2007 6:34 pm
by chichibabin
Thanks Guy's. I guess I will try 0.08% TFA in my MeCN.
Cheers,
Sat
Posted: Sat Feb 24, 2007 12:31 am
by jzt
does anyone know if the same trick will work with methanol mobile phase? i.e., mp A is 0.1% TFA in wter, mp B is 0.08% TFA in methanol? or do we need a different percentage of TFA in methanol to achieve the same results?
Posted: Sat Feb 24, 2007 4:08 am
by tom jupille
That specific trick is unique to the interaction between THF and ACN. That's why I posted the link to the Rozing article in LCGC Europe.
