Jordi PS DVB columns
Posted: Mon Feb 19, 2007 12:27 pm
Hi folks,
Wonder if someone could help here. I'm coupling 2 Jordi PS-DVB (100 A) columns together for separating glycerol monostearate. The mobile phase is THF. Detection is via RI.
The setup work for us before. However, one of the columns recently died and was replaced by another one. We were assured its the same type; indeed it was. However, I noticed the new column has a different catalog number. So effectively, I'm coupling 2 similar columns with different catalog numbers.
Is this really a cause for concern? The analysis doesn't work now - we keep getting a negative peak where the free glycerol should elute. This is happening even hours of equilibration and balancing. Mobile phase the culprit?
Thanks in advance.
Thanks in advance.
